did know where to go for help
my 240 is now off the road so i got a senta and know that is all ****ed up i need help
no start no brake lights no blinkers no inside lights work help!!!! :dunno: :mad: |
battery, fuses, alternator, starter
probably the battery..
agree w/ snickers
check battery and cables coming from battery. i know my friend thought his starter was bad, bought a new starter, i told him to test the battery. we tested the voltage and it was dead (i think a DEAD battery shows 10v or 10.5volts or less) so yeah, check battery voltage too, if it's less than 10volt, your battery is DEAD, so charge. when you get your car started, check your battery voltage while it's running. this will give you your alternator voltage i think (or just test at alternator) |
well my friend parked one of his cars in the garage during the hurricanes..and hasn't started it for almost 3 weeks..none of the inside lights would turn on, parking light, and it wouldn't start....but it was just the battery..
3rd on the list suggesting "battery and battery connections"
alternator fuse, worked for me!
most likly, its just fractured, if you rev it really hard does it come on? let me know if so then go get the alternator fuse, its the best 15 i ever spent! thats all, -slo |
battery/ wire crap? :dunno:
