driveshafts?
Old Mar 21, 2007 | 03:21 PM
crazydrifter's Avatar
driveshafts?
I know that a 5-speed driveshaft is shorter then an auto one but what is the difference between a driveshaft with ABS and one without ABS besides the fact that one has ABS and the other dosent
Old Mar 21, 2007 | 03:55 PM
nightkid86's Avatar
Front Half: 5 speed/auto dependent - auto is longer
Rear Half: ABS/Non ABS dependent - Non ABS is longer
Old Mar 21, 2007 | 04:12 PM
yup.........................
Old Mar 21, 2007 | 07:25 PM
so if i was to put a 5-speed tranny into an atuo with ABS i should use a driveshaft from a 5-speed with ABS because no other shaft will fit
Old Mar 21, 2007 | 07:35 PM
yea u cant mix match hardly any abs/non abs parts. for example. wheel hubs are sold based on year with or without abs
Old Mar 21, 2007 | 07:52 PM
well dam i really hope i got the right one from the junkyard is there a way to check to see if its ABS
Next Level 240
Jan 13, 2005 07:43 PM
importer9
Jun 14, 2003 04:04 PM
spitz7985
Nov 12, 2002 02:37 AM
