fuel filter change
Old Oct 19, 2003 | 04:08 PM
crimsontide240's Avatar
fuel filter change
Where is the damn thing?
Old Oct 19, 2003 | 04:10 PM
fist's Avatar
under the car close to the gas tank probably...?
Old Oct 19, 2003 | 05:13 PM
Ive looked all under the car, near the gas tank, tried to follow fuel lines to the filter but no luck. Tried to do a search on the site and came up with useless info. I'd like to change it out tonight if I could just figure out where the damn this was...
Old Oct 19, 2003 | 05:18 PM
Hella 240's Avatar
just changed mine... in a 1992 its near the oil filter, its a little smaller than the oil filter and is in an upright posision. its held in place with a little clamp. Sorry id take a pic but my digital camera is at my friends house. hope this helps
Old Oct 19, 2003 | 05:23 PM
fist's Avatar
thats a good description hella...he should get it from that..
i'm sure you have the new one near by...so look by the oil filter...get some bright light there..
Old Oct 19, 2003 | 05:24 PM
drnovascotia's Avatar
Copied from **********.
"It’s on the right side of the engine bay (right side when looking out the windshield) attached to the strut tower about halfway down. It looks like a little silver can with one black hose going into the top of it and one black hose coming out of the bottom.
Take off the gas cap, take out the fuel pump fuse in the fuse box by your battery. It should show you where it is on the cover. (Note: Fuel Pump fuse is in fuse box by left foot in North American s14. Shawn Schembri)
Crank the engine and it should start, then immediately die. Loosen the clamp on the top hose and slide the clamp up on the tube, then tighten it so that it squeezes the tube shut a bit (not too much to rip the tubing!!), then do the same for the lower tube. Now mine was a ***** to get off because the filters have nipple like plastic tubes coming off the filter that can seize to the rubber fuel tubing a bit because the tubing gets hard over time. It took some effort to get the damn tubing off. (Note: Twist the fuel filter while holding the tubing. The twisting will help loosen the connection. Pulling straight out will only result in cut knuckles or a sore elbow. Resist the urge to use pliers on the tubing, it'll damage them and cause a leak. Dave Balingit)
Once they are off some gas will spill out so I'd put a old rag or towel underneath the filter to absorb any gas that spills. Oh, and don't smoke! (if you do)
Then put the new one in and attach the hoses. Re-tighten the clamps where they were on the original. Overall if the tubing comes off easily its a 15-20 minute job.
Kris -- 1990 240SX
These hoses are hard to remove.
Solution:
Pliers can and should be used. Just put several plys of tape or a towel over the rough part on the pliers. This will protect the hose from being torn and damaged. Then do some twisting and working of the hardened hose. Then finally you can pull off the hose. Never pull from the beginning. If you have enough slack just cut the hose ,which will give you a snug fit when you re-attach it.
Brett S.
Email: Phsinvent@aol.com
Can't get the top hose off?
Solution:
I just replaced my fuel filter again the other day and found that if you remove the bottom hose first you will then be able to pull the filter out and twist it away from the top hose - that's the one that gives us the most problems. After I slid off the hose clamp the bottom hose came off rather easily! BTW - Use the late model 300zx fuel filter as described in the Product Reviews, it really helped speed the revs up dramatically. "
that should help
Dr.
Old Oct 19, 2003 | 06:41 PM
Hey thanks a lot guys! I found out where it was and I changed it out. I had already done it by the time you 3 posted. I found the site that dr was talking about. Thanks a lot for helping out guys!
Crimsontide
Old Oct 19, 2003 | 06:43 PM
Didn't have time to get the 300zx filter. I'll probably go and get one tommorrow and just do it again!
Crimsontide
Old Oct 19, 2003 | 08:11 PM
NP, thats what we're here for
Dr.
Old Oct 20, 2003 | 12:21 PM
fist's Avatar
whats the story behind this 300zx fuel filter...what differences are there???
i did try a search...but none of the thread subjects were good...i checked a few of them..
i heard revs faster...what else? is it noticably a faster revving engine?
whats the price differences? details peoples
Old Feb 23, 2004 | 12:53 PM
fist's Avatar
i bought a 300zx fuel filter...its installed now i believe but i havent driven my car yet as its getting an exhaust manifold bolt replaced.
answer some of my own questions.....300zx filter was CHEAPER...and its much larger in diameter...
Old Feb 25, 2004 | 03:46 PM
JeromeS13's Avatar
You will NOT notice a difference. It only allows more gas to flow through.
Old Mar 3, 2004 | 05:09 PM
fist's Avatar
maybe you would notice a difference if your car demanded more fuel...say from forced induction.
Old Mar 4, 2004 | 08:38 AM
sleighty's Avatar
I have had the 300zx turbo fuel filter on for a few weeks and their isn't a oooh wooowwww effect but the revving is a tad bit quicker. I have also noticed that revving down takes a bit longer too, but all in all it is a good cheap upgrade....
Limited Slippin
Mar 17, 2016 09:27 AM
don
Feb 18, 2011 11:15 AM
BILLYhoang
Mar 17, 2008 08:51 AM
uofa240
Oct 16, 2003 08:51 PM
uofa240
Jan 12, 2003 08:00 PM
