Fuel Pump Gasket.. does it exist?
Old Jan 16, 2005 | 11:51 AM
nickelmedia's Avatar
I have a leak around the seal between the fuel pump surround and the fuel tank. When I pulled the fuel pump, I noticed there is no gasket. Should there be?
I have some high temp red silicon that I want to use to create a gasket, but the instructions say 'not for use on products continually submerged in gasoline.' I'm thinking we should be fine because it SHOULDN'T be continually submerged, should it?
Old Jan 16, 2005 | 01:59 PM
rudee023's Avatar
There is a rubber O-ring that goes there. You can get it from the dealer.
Old Jan 16, 2005 | 03:11 PM
I do see where that is supposed to go. I bought a roll of gasket material and fabbed a new gasket. Hopefully it will hold. I know the ridge where the O-ring goes will hold fuel, but it should be fine.
Old Jan 19, 2005 | 05:54 AM
wikd240's Avatar
get the rubber o ring from the dealer or go to napa or any other parts store to get it... the rubber o ring compresses when the pump assembly is re attached to the gas tank... a flat gasket will not compress the same way ou in the right places like the o ring does...you are going to leak fuel if you use a flat one... get the right one...
nsn240
Oct 20, 2006 09:50 AM
dak2007
Apr 9, 2006 09:38 AM
WERDdabuilder
Feb 17, 2005 07:43 AM
RNN14
Feb 28, 2002 01:33 PM
