Gas Gauge
Hey guys Ive got a problem. The other day I was fooling around with my friend, doing some burnout, and sliding around. On the way home i notice my gas gauge going up to F when I only filled it up half way. What do you guys think this could be? If you know what it is, whats the estimated cost in repairs? Thanks for the help in advance guys.
Thanks, Eddy |
yo bro same exact thing happen to me! did you ever fix it? What was wrong?
You might have jacked your fuel float. The cost is not expensive if you trust yourself or a friend to take out your fuel pump to check the float assembly.
This happens to a lot of guys that screw around. You are not alone :D Give me a shout we have guys that can help you if needed. |
I think it may have fixed itself, but i cant really tell since my cars been down (or up because its on jackstands) for a week+. But ill let you guys know when i get it on the ground again. But thanks for the help.
the same thing is going on to my car. but mine when its half empty it starts to work again and thats how i know when to re fiil, another way is just re fill every 200 miles. i hope ou fix it
WOW that's like something nissan should have recalled.
freakin weird problem even if it is common |
