General 240 Problems
Well I thought I would just make a thread and everyone should/could add to typical problems that they have noticed with the 240's, People can review it when buying and know where and what to look at
So far I know of:
Sunroof Whistle at high speeds
Power steering leaks
rotted hatch's due to spoilers
timing chain
Valve cover gasket
Not sure if its common, but my S13 has bad electrical problems
Just off the top of my head, Add if you want to
So far I know of:
timing chain
Valve cover gasket
I found a way to silence the sunroof...at least the hatchback sunroofs. I cut tiny holes in the weatherstripping, and fill it up with silicone... Ive seen some use very small amounts of that expanding foam with good results as well.
fer sure
Originally posted by RX7Zero
I cant beleive no one has metioned the crack addicted dashs.
AND THE FACT NO ONE SELLS HUD DASHS DAMMIT!!!
the upholstery on the drivers seats ripped
two words "tin can"
changing leaking coolant hoses that are impossible to change that you have to take the intake manifold off for is expensive and sucks fer sure
theres a whole in the truck
hole where my intake filter chills
The alternator issue is with all nissans...
check to make sure the alternator mounts are clean as for good grounding and also check to make sure the positive wire is run well. dont buy nissan alternators they suck.. spend some cash and get a good alternator with a warrenty!
