-   General (https://www.s-chassis.com/forums/general-3/)
-   -   grinding suspension (pics) (https://www.s-chassis.com/forums/general-3/grinding-suspension-pics-22358/)
Mika May 1, 2005 04:58 PM
sooo i get this really loud ass grind in my suspension when i make a fairly sharp left turn and today my dad and i jacked up the car and took a look, now neither one of us is an expert car mechanic but we think we found the problem, he also said looks like we could replace it fairly easily but we need some booklet (sorry the name has slipped my mind)
wat do u guys think?
http://img200.echo.cx/img200/5463/p00009947qo.jpg
http://img138.echo.cx/img138/1525/p000099517zi.jpg
http://img138.echo.cx/img138/773/p000099616eu.jpg
tenzenk May 1, 2005 05:03 PM
what's the problem? what needs to be replaced? I dont think that caliper bolt is rubbing anything.
Mika May 1, 2005 05:39 PM
dad says he thinks that that's a bearing thats broken and it should be straightly aligned...but as i said were no experts, so i came here :)
wikd240 May 1, 2005 06:22 PM
here is a link for the fsm or the booklet thing you were talking about... it is a little way down under s14
http://www.zeroyon.com/index/content/view/24/47/
AAV240sx May 2, 2005 03:22 PM
Looks like a oozing oem TC rod bushing needs to be replaced. I replaced mine a while ago. It's really easy to replace if you got a press.
CowboyTurbo May 2, 2005 05:36 PM
yeh ur going to need mechanic tools to get that out or else it's going to suck
Mika May 2, 2005 06:49 PM
well i had it towed to my moms mechanic friend, hopefully its not gonna cost too much and i hope i can get myc ar back soon :(
needa240 May 2, 2005 07:12 PM
shouldn't be over 100 bucks. That is easy to replace with the right tools.
no more than 1 hour.
naptime May 2, 2005 10:25 PM
Tc rods. It is a 10yr old car. let us know how easy the fix was
Mika May 4, 2005 12:28 PM
guy said it was the wheel bearing, cost me 150, im waiting to go pick upt he car soon and we'll see how it goes from there
Mika May 4, 2005 05:31 PM
NO MORE GRINDING :)!
aay May 4, 2005 08:17 PM
You might still want to get the TC rod/bushing changed even if the grinding noises are gone. A worn bushing like that leads to knocks when turning at full lock and makes for weird feeling steering at highway speeds.
Unfortunately, Nissan does not sell bushings seperately, but the entire tension rod is available from them. I paid $55 for mine. If you have access to a press, you can buy a set of replacement bushings for the cost of one new tension rod...
The rod itself is pretty easy to remove - it's held in place by three bolts.
2forties May 5, 2005 09:58 AM
Does the energy suspension contain replacment tension rod bushings in there kit?
kang128 May 16, 2005 09:31 PM
yes it does
