HELP! My sohc is shaking like a little biyatch!
Okay, when it first happended I used Sea Foam and it worked, 2 months later it started shaking agian (so bad it almost shakes my shifter out of gear). I have all new ignition components, oh yeah it seamed to start shaking when I harped on the motor. Any thoughts to why its shaking like a little biyatch?
either a cylinder isn't firing ... or one or more of the motor mounts are broken ... take it to someone who knows ... ask them to check out the mounts, if its not that, then its gotta by the cylinder ... when you hit the pedal, is there any lag or bog?
Alright, I had this problem. In my case, I needed new injectors. Or it could be the wiring to the injectors..
Yeah Im thinking it might be the injectors because its a random problem, sometimes it runs alright, then the next minute it runs like crap. I am going to try the injectors first then I will post my outcome.
mine shakes when I start it up in the heat... at least when it idles, it goes crazy... wonder if that's the same thing?
mine was shaking because of bad plugs and bad wires I'd post pics of it but it's on pic of the day thread somewhere. I don't want to repost hehe
