Hood Pins?
I need to install some hoodpins on my car due to a best core support and the latch no longer holds the hood very well. Anybody recomend a place to put them?
I think your hood would be a good place.
thanks for the smart ass reply. I actualy would like to know where on the core support is a good place.
put them close to the head lights... that is where the core support is... core support is the radiator support... put them as close to the corners as you can but make sure that there is a few inches from any outside edge...
You didn't give much to go on. You said your support was bent up and that will play into where you put the pins.
its bent from behind the drives light down to about 1/3 along the drivers fender. But it looks like im gonna hafta cut and weld that whole new chunk in there.
Originally posted by down_shift I think your hood would be a good place. |
| All times are GMT -7. The time now is 02:59 AM. |
