how do i find out what options
Old Jun 27, 2005 | 08:01 AM
Shri222's Avatar
I got a 91 240sx coupe SE, it has HUD, and my car fax says it has ABS, but i've never felt it kick in, and i have never been able to lock up. I know ABS give a pulsating feeling on the brake peddle but I've nev er felt any. Also dose the SE coupe come with LSD. I had the KA in there, never been able to do a burn out in a auto KA. It's in the shop, getting a CA and a 5speed. I wanna know if i still need to save for a LSD..
Old Jun 28, 2005 | 02:25 AM
lrb_2000's Avatar
like I said in the other thread. It's an SE... so it has ABS and LSD.... I'd probably search stuff like this.. but SE is the special edition or whatever, so it has everything.
http://garage.projectraine.com/
go to Guides.. there's a writeup there.
Old Jun 28, 2005 | 05:58 AM
Initial Daniel's Avatar
I don't know why you keep posting new threads about the same question? If you have ABS then you most likely have LSD. You can't really do burnouts in an auto...well you can, but it's going to be a lot harder to get the revs up in order to break traction without hurting your tranny.
To be honest with you LSD is better than no LSD, but the factory Viscous LSD isn't very good at all. It's not as grippy as a lot of aftermarket LSD's out there. You can still peg-leg if you're doing a burn out, and it doesn't guarantee lock up 100% of the time. If you've got the money to spend on getting a CA, why skimp on the LSD? You should probably get one reguarless...
Do a little research before you do anything more. The search button doesn't hurt. You've been a member since 2002. I don't mean to bust your ***** or anything, nor am I trying to offend you, but you should know better.
fanmanflex
Mar 26, 2008 12:33 PM
USMCDrifter
Jul 30, 2007 02:50 AM
2fast4y0u
Oct 13, 2006 05:52 AM
Eric
13
Feb 21, 2005 10:21 PM
Sleeperella
Feb 6, 2005 11:43 AM
