Uneven headlights
Old 03-17-2010, 11:07 AM
lifted&lowered's Avatar
Uneven headlights
On my 91 240sx my headlights are uneven when I do the sleepy eye. If there all the way down or up there even, but once I do the sleepy eye by tapping my headlight hold switch the driver side one is a bit higher when I do it. So is one of my motors shot? or is it out for adjustment? I'm lost. Thank you
lifted&lowered is offline
Old 03-17-2010, 05:43 PM
One of the motors is probably just slower than the other. I don't have an s13 but I think you can adjust the little gears to offset it a bit.
silviaks2nr is offline
Old 03-17-2010, 07:26 PM
yes sir you can to the left and right of each headlight.. there is a motor. you pop the top off and adjust the height. also remove the bezel around the light.
you adjust the beam with the two screws
Biggamehit is offline
Old 03-17-2010, 08:11 PM
Alright well I knew that I can adjust them up or down with the red **** on each side. but once the lights cycle up and down they go right back to normal. I think my driver side motor is slower cause I watched them today and my passenger side stopped a split second before the other
Old 03-17-2010, 08:21 PM
get new motors..... nothing you can do about that.
Old 03-17-2010, 09:52 PM
USMCDrifter's Avatar
/thread?
USMCDrifter is offline
battery1882
05-26-2005 03:34 PM
advanced240
04-25-2005 08:20 PM
CowboyTurbo
03-23-2005 02:01 PM
WinterHillGang
08-16-2002 12:50 AM
RNN14
03-03-2002 02:44 AM
Quick Reply: Uneven headlights
