ka24de trans fit a ka24e?
i am in need of a tran fairly bad, i found a guy with a ka24de with thrown rod comes with 5 speed tranny clutch pressure plate shifter and ecu and non cut harness and drive shaft and mount for $200
one of two things, A will the tranny fit up to the sohc? B will they head match up to the SOHC block? :help: |
Yes they are all the same.... the only difference is the Crank angle sensor is mounted in the S14 bell-housings.... just remove it.. it doesn't affect anything
will the 89 ka24e manual tranny fit the ka24de 98?
it will fit.. however.. there is no location for the crank angle sensor on OBD I bell-housings..... so you will have to with precision drill an exact hole.. and or swap the bell housing.... not worth the hassle.
