LED's flickering
Most recently, I've been having my Break, and Battery LED lights flickering and making noise. Usually, they would flicker when I washed my car, and stop once it was totall dried. But now its all the time!
:angry: Anyone have similiar annoyances with their instrument panel LEDs flickering, and possible know how to fix them. |
i don't think the instrument panel has LEDs, so maybe it's a loose connection on the bulb...
you could take out the gauges and check the bulbs, but i don't know what size those are. |
what's the condition of your battery and terminals?
1 Attachment(s)
All terminals are 100%
I'm using a red top optima. i utilized the top, and side terminals. top terminals are nickle plated, that i use for my stereo power wire and grounding the chasis/motor. side terminals are used for grounding, and all other car electronics. i looked them over, all are rust free and tight. I believe my short problem is behind the dash somewhere. |
The "car wash" reference then might point to maybe a water leak somewhere, where te water might be hitting some wires maybe, causing a short... maybe
1 Attachment(s)
Here's a closer look at what is going on. These lights flicker when I hit the gas. I have a small video clip if anyone cares to see that
Originally posted by l2aine The "car wash" reference then might point to maybe a water leak somewhere, where te water might be hitting some wires maybe, causing a short... maybe |
Normally I think that means your alternator isn't charging . My alternator belt broke one night and those two lights came on .
| All times are GMT -7. The time now is 07:10 AM. |
