Limited Slip Differential
I'm lovin this forum, you guys reply so fast. Anyhow, I was wondering if any 240SX's came with an LSD out of the factory. From what I've understood so far, it had to be specially ordered that way from the factory which means basically none had it. So when you are starting from zero and want to smoke the tires a bit, only one is going to smoke right? A decent LSD costs what? $800 new?
s13 240 is right but you can find a vlsd from a jdm s13 for about $300-400. that will be your best bet is to buy the whole thing you dont wanna have to rip it apart to instal an lsd. thier is also away to weld your stock one but when you take corners it hops a little.
