Lower Control Arm FAQ?
http://www.pdm-racing.com/products/pdmcontrolarms.html
I want to get a set of front lower control arms, but i want to knoe if its a big job to replace, because i want to do to job myself, but i want to figure if its too hard of a job for me to handle so i would just take it to the shop, anyway does anyone know of a FAq to replace the arms? if possible i want to try it the right away instead of further messing up my car |
noone eh? not even an idea of where?
pretty straight forward, I remove my entire front knuckle because i was changing the hubs, it may not be neccassary to take everything off but it makes geting to everything a lot ez'ier. Just be careful with the ball joints. I replace mine for 25 bux each from the local auto parts store. If you mess up your ball joint you will need to get the old ones presed out and new pressed in.
| All times are GMT -7. The time now is 03:47 AM. |
