makeing sure?
ok i done my research and the only thing thats got me confused is the wireing
from what i understand u guys use the lower engine harness(given) and the harness that came with what ever motor ur useing (exp sr20det red top) with some moding, or am i using the stock harness from my ka and moding it to the sr motor? witch is it, need to kno, if i plan on doing this swap. i found some good source of info to wire it up but dont kno what harness to use if u can tell witch it is and how hard it is to convert ether harness that be great cuz i have no problem converting it my self sr20det red top in an 95 240sx |
the only harness you will be taking out of your car is the engine harness from the KA, and when you get your SR, you'll splice in the SR engine harness. At least I'm pretty sure thats how it goes.
that part that had me lost, im reading the swap readup and when it get to the wireing im like "yes im gona love this part" (love to wire **** up)butt had to make sure witch harness to use
and keep up the work on ur s12 good job i should have my car up here soon once i get back from my uncles machine shop |
