Metallic Knocking Sound In Engine????
Old Oct 29, 2006 | 10:17 AM
jerry7784's Avatar
Thumbs down Metallic Knocking Sound In Engine????
sup 240 lovers, i have an sr20det motor and my car is running fine, only thing is that i have a metallic sound in my engine?? its not affecting my performance as far as i know, but it sounds like a lifter or rocker arm went out... anybody ever had this problem before and if so should i just spend the money to upgrade all my internals??
Old Oct 29, 2006 | 10:52 AM
spun bearing?
Old Oct 30, 2006 | 03:57 PM
mabey something to do with vavle train too. is it a loud thunk or like a tap?
Old Oct 30, 2006 | 06:37 PM
tehott240's Avatar
you may have a bent or burnt valve or a bas rocker arm that is causing a tapping sound. you should be able to tell if it coming from the top of the engine or the bottom.
Old Oct 30, 2006 | 07:05 PM
jerry7784's Avatar
its coming from the top, its not loud, its subtle you have to really listen but yeah its more of a tapping your right! how much yalls think it'd cost to buy everything to upgrade my engine
Old Oct 30, 2006 | 07:16 PM
Originally posted by jerry7784
its coming from the top, its not loud, its subtle you have to really listen but yeah its more of a tapping your right! how much yalls think it'd cost to buy everything to upgrade my engine?
thats a very open ended question (i added a "?" to the end since you didn't)
Old Oct 30, 2006 | 10:29 PM
re037's Avatar
just get your cam clearance adjusted
FOSINGWO
SR
Apr 17, 2007 01:56 PM
jackyliem
May 31, 2005 02:29 AM
topsecretgold
Mar 25, 2005 02:00 AM
1sic7
Jan 6, 2005 08:31 PM
romeobrood
Jan 18, 2004 09:22 PM
