-   General (https://www.s-chassis.com/forums/general-3/)
-   -   Metallic Knocking Sound In Engine???? (https://www.s-chassis.com/forums/general-3/metallic-knocking-sound-engine-35659/)
jerry7784 Oct 29, 2006 10:17 AM
sup 240 lovers, i have an sr20det motor and my car is running fine, only thing is that i have a metallic sound in my engine?? its not affecting my performance as far as i know, but it sounds like a lifter or rocker arm went out... anybody ever had this problem before and if so should i just spend the money to upgrade all my internals??
silviaks2nr Oct 29, 2006 10:52 AM
spun bearing? :(
MS!3 Oct 30, 2006 03:57 PM
mabey something to do with vavle train too. is it a loud thunk or like a tap?
tehott240 Oct 30, 2006 06:37 PM
you may have a bent or burnt valve or a bas rocker arm that is causing a tapping sound. you should be able to tell if it coming from the top of the engine or the bottom.
jerry7784 Oct 30, 2006 07:05 PM
its coming from the top, its not loud, its subtle you have to really listen but yeah its more of a tapping your right! how much yalls think it'd cost to buy everything to upgrade my engine
silviaks2nr Oct 30, 2006 07:16 PM
Originally posted by jerry7784
its coming from the top, its not loud, its subtle you have to really listen but yeah its more of a tapping your right! how much yalls think it'd cost to buy everything to upgrade my engine?
thats a very open ended question (i added a "?" to the end since you didn't)
re037 Oct 30, 2006 10:29 PM
just get your cam clearance adjusted
