motor swap
hey guys,
okay my name is austin and im new to the whole motor swap. I have a 1996 240 sx and wanted to swap for a RB 25 motor.. now theres talk of overheating? Is there extras i need to buy for this motor switch such bigger radiator or oil cooler..? |
First off, no reason to make two threads asking the same question. Second, read this thread:
http://www.club240.com/forums/showth...threadid=10661 When you're swapping the 2.5 or 2.6 you're going to need a couple more mods. You'll certainly need a new driveshaft, because the 2.5/6 uses a larger one then the stock 240SX. You'll also likely need a new downpipe and may have to shave your hood a bit for clearance, depending on if you used a mounting kit or the Skyline crossmember. Certain plumbing and piping will likely have to be custom made as well. |
| All times are GMT -7. The time now is 08:25 AM. |
