-   General (https://www.s-chassis.com/forums/general-3/)
-   -   my 1995 a OBDI or OBDII (https://www.s-chassis.com/forums/general-3/my-1995-obdi-obdii-28660/)
barcode Dec 3, 2005 08:56 AM
welli read all over the forums and they say some of the 95's are OBDII, but i dont know any visual diffs, some guy said look for a diagnostics port, when i did i saw a lil plug right above all the fuses, no idea if its a diagnostics port, so i need to know if yall have any visual differences between the two. Or if that plug is a diagnostics port.
Gnnr Dec 3, 2005 01:22 PM
All 95s are OBDI. I have a 95 and I went through this dilema when looking for a replacement KA. If you have a single wire going to your o2 sensor, it is OBDI. There are some other visual things, but I forget. All S14s have that diagnostic port.
Kaion1000 Dec 3, 2005 01:54 PM
Not all 95s are OBDI, I have an OBDII 95. I think you can look for an 02 sensor after the cat if its OBDII.
barcode Dec 3, 2005 05:16 PM
well OBDI, looks like no greddy turbo kit for me:tear: :tear: :tear: , o well i guess i will have to find some other one.
Gnnr Dec 3, 2005 09:57 PM
If you want a turbo kit go here: http://www.import-autoperformance.com/240sxstage1.html
But honestly it would be much cheaper to piece the parts together yourself. Go to Ka-t.org and do some research.
BigVinnie Dec 4, 2005 12:04 PM
Originally posted by Gnnr
All 95s are OBDI. All S14s have that diagnostic port.
This is false.
To tell the differences in OBD1 and OBD 2 there are a couple of differences in smog equipment.
Things to look for in OBD 1 SCV, one CAT, and one O2 sensor.
Things to look for in OBD2 1 CAT butted to the exhaust manifold, a resonator after the CAT and 2nd o2 sensor.
Early 94 production s14's were OBD1
Production that continued (I believe after August, not shure) was OBD2.
barcode Dec 4, 2005 08:18 PM
well crap looks like i got OBD1.5.....got the one O2 senser, and a resonator after my cat, but my cat is not butted, its bolted....Im just gonna keep thinkin its OBDI lol:dunno: , well slash the turbo, I got tranny prolems now, its barley shiftin and, I notice my O/D off light flashes like 16 times when I turn the key on. I dunno what that means and I have tried lookin it up but no luck so.....Ill have to figure it out....:confused: ...I think Ill check my tranny fluid with the bold instead of that stuid dip stick tomorrow.....then see what happens, would too much tranny fluid cause these problem
BigVinnie Dec 4, 2005 08:30 PM
Sounds like you are still having problems....
Read Raines VIN description it is the sticky in the general forum.....
barcode Dec 4, 2005 08:39 PM
i was jokin bout the OBD1.5, i guess it has to be OBDI cuz theres no second O2 sensor
Purple240 Dec 5, 2005 12:40 PM
I have an april production date on my 95 (april of 94), and its OBDII.
dued Feb 13, 2006 10:51 AM
My 1995 240sx was manufactured in May of 1994. I have a sticker that says the OBD port is on the passenger side. Do you guys know if it is OBDI or OBDII?
Bryan Feb 13, 2006 01:36 PM
did you look for the second o2 sensor
dued Feb 13, 2006 04:57 PM
I'm very new to working on cars. I apologize for asking so many questions. Where should I look on my exhaust system? Can I see it without using a lift?
BigVinnie Feb 13, 2006 04:59 PM
Look for this thing called a bung, it comes with a hole.....LOL
After the cat that is butted to the header....
Bryan Feb 13, 2006 05:20 PM
heh....bung hole...
