my high beam is out?
Im curiois if any1 would know whats wrong with my highbeams
my left highbeam went out. I checked the bulb and it was good. What i did is do a current test to see if the wire had power running through it to the lights, but nothing. Is it the plug harness or maybe a loose calbe or a fuse? Right now i have a wire running from the highbeam on the rightside powering both highbeams... edit** my fuses are fine |
step one buy new bulb or swap from other side
step two come back and tell us whats up |
still nothing. i swappe them and it is still out
s13 of s14
if i rember right in the s14 theres a sub harness that goes the the high to low light check that out |
alright. ill try that out when theres some sun out
My right high goes out and occasionally if i flash them, both are out. it has had this problem for years.
Funny thing....
... I'm in the same boat! I noticed in early spring that my RHS high beam quit. The low beam was still good, so of course, I replaced the bulb and still no high beams! I kinda forgot about since I rarely use them, but now, days are getting shorter....
I haven't done any trouble shooting yet, but I wouldn't be surprised if we had the exact same problem. Thanks for reminding me! |
i had both of mine go out at the same time. but mine was easy, replaced bulbs
check the fuse box - you said the fuse was fine but check to see if there is power going to the fuse. remove the fuse turn on the lights and put a volt meter in the fuse hole. |
my dad said it was a problem with the "pigtails" for the lights. dunno what that means.
I had this problem. It's common. You need a new switch.
Switch? What switch?....
Originally posted by steve 14 s13 of s14 if i rember right in the s14 theres a sub harness that goes the the high to low light check that out |
what?
yeah they do
Originally posted by Madman Stephan Switch? What switch?.... |
