Need Help: High Beams
welcome to the forum man. A lot of your questions can be answered in the FAQ. Also the search function helps a lot.
Anyway what the problem most likely is the light switch. you have to take it off the steering column and take it apart. In there there is a metal arm that rubs against a contact area when you flick the high beams on. well anyway just make sure its touching.
heres more info on it.
http://www.240sxforums.com/forums/sh...ight=high+beam
