Newbie questions & Compression Testing ...
Old Feb 1, 2004 | 09:12 AM
NickSimcheck's Avatar
I'm a newb and I'm looking at getting a '98 and I ran it threw Carfax, which didn't say if it was a SE or LE. So first off, how do I tell the difference? I know the base had 4 lugs. Also, when I run a Compression Test what PSI should I expect? And where do I pull the fuel injection fuse from?
Thanks for the replie(s),
Nick
PS - I'm in Michigan and the car is in Florida and I'm leaving on the 8th.
Old Feb 1, 2004 | 09:18 AM
Oh and is there any web page with general specs like vehicle weight and **** like that?
Thanks again,
Nick
Old Feb 1, 2004 | 09:24 AM
Sil40_Mayhem's Avatar
welcome to the boards. i'm not certain about the compression testing, but i do know where u can get info about the different trim levels and basic specifications:
http://www.edmunds.com
http://autos.msn.com/research/vip/de...=category#used
Old Feb 1, 2004 | 09:55 AM
So is seems as if the difference between the SE and LE is the sunroof, leather seats, & CD came standard. And the leather was N/A for the SE. Intresting...
element's Avatar
i believe 10% leakage and under is what it should be(normal) but i think it's still ok if it's 15% or so... just means it's leaking somewhere more.
Old Feb 1, 2004 | 10:35 AM
For the compression test...each cylinder should be reading around 170, plus or minus 10. Those are the usual numbers for a warm engine
Old Feb 1, 2004 | 10:43 AM
drnovascotia's Avatar
anything aboe 150 is good, hopefully closer to 170 on a new car. Look out for variation between them.
Dr.
Old Feb 1, 2004 | 07:56 PM
Ok cool, it's got 47K miles so I'll expect around 160-165. 150 is the service limit then?
Thanks for the help.
Nick
Old Feb 1, 2004 | 09:48 PM
yeah, lower than 150 isn't so hot, especially on a newer engine.
check the FAQ's as well for common s14 problems.
Dr.
wannaS15
Apr 12, 2006 05:18 PM
240baja
Feb 16, 2003 01:19 PM
agressiveracing
Northeast
Oct 30, 2002 09:27 AM
iceperformance
Oct 8, 2002 07:23 AM
rbboyl
Sep 24, 2002 10:02 PM
