-   General (https://www.s-chassis.com/forums/general-3/)
-   -   Oil Type and Idle Control (https://www.s-chassis.com/forums/general-3/oil-type-idle-control-24802/)
SpeedDemon4x4 Jul 22, 2005 01:56 PM
First what kind of oil does the manufacter tell you to put in the S13 ? And secound the car idles at 1600 RPMS.. How do i adjust this so its not so high..Or is it supost to be this high.... Thanks!
motegineon Jul 22, 2005 04:10 PM
Just run 5 or 10w-30 oil and as far as the idle it could be lots of thing, check to see if ur throttle cable is sticking or your maf could be reading wrong, air/fuel could be wrong....a multitude of things really could cause a high idle...
SpeedDemon4x4 Jul 22, 2005 04:52 PM
Whats a common problem with the idel?
jt1583 Jul 22, 2005 06:34 PM
did you just get this car or do a swap or something?? did it just start doing it out of nowhere? check for vacuum leak
SpeedDemon4x4 Jul 22, 2005 06:44 PM
Just got it.
lrb_2000 Jul 22, 2005 07:55 PM
you can unplug the TPS sensor, start your car, adjust the idle screw till its about 700rpms, turn off the car, plug the tps sensor back in... should be good to go.. go buy a book for your car, it helps a lot... plus searching the forums and internet works too.
SpeedDemon4x4 Jul 23, 2005 09:30 AM
Care to take a picture of were the TPS is loacted? THANKS! :thumb:
lrb_2000 Jul 26, 2005 03:41 PM
what year is your 240? Is it SOHC or DOHC motor.. the TPS connects to the throttle body which is connected to the intake manifold... its a little black box looking thing attached with two screws.
here's a pic for the DOHC.. the arrow is pointing to the connector..
http://www.myweb.cableone.net/downtownsb/engine.jpg
and for the SOHC, it's the little black box, you just follow the wire and there should be a connector you unplug...
http://www.myweb.cableone.net/downtownsb/engine2.jpg
SpeedDemon4x4 Jul 26, 2005 07:24 PM
Its DOHC... And it has a cold air intake. Maybe the sensor is not there. Ill have to check it out.
lrb_2000 Jul 27, 2005 01:05 AM
... it has to be there, it's what tells the computer how much throttle you're giving it.. It's connected on the right of the throttle body.. get a book for your car, they help lots.
