Overdrive
is it ok to leave it on all the time? does it hurt the engine/transmission/anything else to do this? it saves alot of gas...lol..just worse acceleration and such. i worry too much about my car..haha
Re: Overdrive
Originally posted by TonysS13
yep leave it off when your not on the high way,i always argue about that with my sister and dad lol
Originally posted by malicex000
i hear your suppose to leave it off when your going about 60 or higher... it does save gas... and for some reason the car feels lighter... its kool... i should use it more...
looool going 60 leaving overdrive off, ur kidding....that waste even more gas i supposed, 3rd gear at 60 it's like at about 5000rpm.........no offense but what are smoking? looool
it's ok to leave overdrive on....dont really matter that much....
i've been reading most sites and they say to make sure that you have overdrive on. It saves gas is its usually reason. Well I would want to save gas at these prices.
Who said to take the OD off on the highway, it should be the other way.
thanks for the advice. before i really understood it i didnt really use it. i noticed it revved real high on the freeway, lol. later i started just using it on the freeway, but i thought that the car should be getting better gas mileage than it did, and that i was getting ALOT better on the freeway. so now i just leave it on.
Originally posted by manofthug
i know.....here' the steps to drive an automatic manual car
1) overdrive off
2) L1
3) D2
4) D
5) overdrive on
looooooooooooooooooool
1) overdrive off
2) L1
3) D2
4) D
5) overdrive on
if u have an auto ur overdrive is on all the time, when u push the button to turn it off the light comes on to remind you that overdrive is off
from what i know, does nothing to your car, just saves on gas a lot
Originally posted by StanBo
I thought autos were only 4 speeds?
D1
D2
D w/o OD
D with OD
D1
D2
D w/o OD
D with OD
L1 (First gear only)
L2 (First and second gears only, depending on vehicle speed.)
D w/o OD (First through third gears only.)
D with OD (All four gears used.)
