p/s pump removal
- my ps has to come out. it leaks so much that i have to fill it every three days. My questions are: 1) i cant remove the belt because it runs the water pump, but when i plug the rack, is the pump going to whine if their is no fluid in it?
2) Can i buy a shorter belt so that i can remove the whole pump? |
well you can get an electric waster pump or you can just cap all the ps stuff of..
put fluid in the pump and cap it off... i have been running my pump as the adjuster only for 5 years now no issues. the reason you cant do a shorter belt is, you need an adjuster and that is the P/S pump |
