-   General (https://www.s-chassis.com/forums/general-3/)
-   -   Patching up a radiator (https://www.s-chassis.com/forums/general-3/patching-up-radiator-32249/)
vortxxe Apr 30, 2006 12:00 AM
I have a cracked rad and seeing as it looks like i'm most likely going to just get an engine swap (and probably get a new rad with that) i may as well just patch up my current one for now.
I've heard JB weld works well.
Anyone got a tutorial or suggestions? is this a bad idea?
dak2007 Apr 30, 2006 07:57 AM
i used orange gasket sealer. it worked all winter for me but wouldn't recomend it if you are going to use a/c. your best bet if you're trying to go cheap is a junk yard.
All Mighty KA-T Apr 30, 2006 04:10 PM
i seen on myth bosters that you can use a Reg. Egg to seal up a radiator, just poor it in the radiator and it will seal it up.......:p
Crazy, but it works.....lol
juujai May 4, 2006 09:25 PM
jb weld works fine the resin with steel mix. but depends where the damage is. the plastic end tank right?
vortxxe May 5, 2006 01:21 AM
yes, plastic end tank.
RandyJordan May 8, 2006 04:22 PM
use EGG FTW
it seals it up so you can drive around town
Mustang Boy May 9, 2006 03:59 PM
i have a buddy who used to be a mechanic years ago and a raw egg will seal it back up for a pretty long time
another temporary fix is black pepper i dont know how but it works
