-   General (https://www.s-chassis.com/forums/general-3/)
-   -   push button start (https://www.s-chassis.com/forums/general-3/push-button-start-37094/)
bob804796 Jan 27, 2007 07:46 PM
push button start
i found a site with these directions for push button start and today i was bored and had some wire and a toggle swicth lying around
1-cut the black wire with the yellow tracer
2- Run the wire to one of the terminals on your starter button
3- Splice into the White wire with the black tracer
4- Run the spliced wire to the other side of your starter button
i put the key in the on position then fliped the swicth she just turned over and over with out starting, but if i turn the key all the way she'll start, am i using the wrong wires or somthing. thanks
20+PSI Jan 28, 2007 02:18 PM
you have two starter wires black/white and black/yellow if you send 12volts to them while your key is on the on position it will start up fine
tehott240 Jan 28, 2007 07:22 PM
some were you used or cut the wrong wire if it will turn but not start. ithought about doin this but dont fill like messin with any more wires.
FLatBlack240 Jan 28, 2007 08:19 PM
whats the website, if you dont mind I wanna check it out as well.
bob804796 Jan 29, 2007 08:52 AM
http://bbs.zuwharrie.com/content/topic,5655.0.html heres the site
i tryed the right wires but all it does is sit there and run the starter it still wont start
AZdrifterS13 Jan 29, 2007 01:16 PM
um isnt that link for a suzuki forum? maybe its different on real cars?
bob804796 Jan 29, 2007 01:49 PM
thats what i thoght, my 240 is still a project so i wanted to ginny pig it for my other cars
Baby_Drifter Jan 29, 2007 02:38 PM
hahah
