Question about the s13 silvia lights?
I have a couple of questions about the s13 silvia lights?
1. are the fog lights supposed to turn on when the head lights turn on 2. if not then how are the fog lights supposed to be hooked up 3. can the headlight beam be adjusted |
1. no
2. OEM foglight switch or add your own 3. yes - look for 2 screws on the diagonal corners of each bulb (on the backside) but remember, Silvia headlights are RHD beam pattern |
your my hero bro thanks alot my headlights will no longer shine hard left thanks again
is there a thread here that overviews the instal of the head lights the triple projecters to be exact i tried to search couldnt come across one
Not sure about S13 Silvia thread, but IIRC unless you get the wiring harness for the headlights, all the plugs are different + there's 4 bulbs to power compared to the 2 on a stock, flip-up front end. If you're using your stock harness you're going to have to rewire to seperate the low and high beam sections. Also, one of the bulbs are H3C (the one you can't figure out if you check them, I think it's either high beam or center fog)
IIRC (goin from the top of my head and it's early in the mornin)bulbs for triple projectors
Lowbeam - H1 Highbeam - H3 Foglamp - H3c And if you have the dual projectors, Lowbeam - H3c Highbeam - H3 Foglamp - H3c |
