-   General (https://www.s-chassis.com/forums/general-3/)
-   -   question.. and i need an answer asap (https://www.s-chassis.com/forums/general-3/question-i-need-answer-asap-24754/)
Unholy FD3S Jul 20, 2005 11:09 PM
i am about to buy a turbo from an sr, will it be difficult to install it on the ka24de. sorry im not to familiar with turbos
silviadriver Jul 20, 2005 11:34 PM
if you arent fimilar with turbos, wth are you doing turboing your car?
thats like trying to sky dive w/o knowing how to sky dive
Unholy FD3S Jul 20, 2005 11:38 PM
i didnt mean it that way, i know how they work and all. its the installation that is bothering me
nsn240 Jul 20, 2005 11:40 PM
well... with the right tools and knowledge, it could be easy... you'll have to buy the rest of the parts, including the intercooler, BOV, wastegate... Find someone/ shop with a mandrel (sp) bender for the piping. Also, make sure your engine is built, lower compression, stronger internals to handle the boost. Larger injecters, turbo timer, boost controler, ECU... all things to think about, make sure you do as much research as humanly possible, it will only help you during the install. There's ungodly amounts of turbo info on the web and in this site. good luck!
Unholy FD3S Jul 20, 2005 11:42 PM
thank you so much nsn240 thats what i wanted to hear
Waynehead05 Jul 20, 2005 11:42 PM
you need a t flanged manifold.
yea
Unholy FD3S Jul 20, 2005 11:44 PM
you got one and if anyone else has parts for the turbo conversion for sale, please post
nsn240 Jul 21, 2005 11:33 AM
no problem man... keep us updated
Fast1One Jul 21, 2005 11:45 AM
You dont need stronger internals if your boosting low numbers...
nsn240 Jul 21, 2005 05:09 PM
if you're gonna run boost, why not make it worth your while and out in some higher numbers
Unholy FD3S Jul 21, 2005 05:33 PM
hey nsn would you happen to know how to install the turbo because you live near me, i would pay you good.
BigVinnie Jul 21, 2005 07:28 PM
Re: question.. and i need an answer asap
What type of manifold are you using? What is the Flange type?
Are you going to use JDM down pipe from the SR? If you are going to run boost what type of EMS and cams are you going to run? What injectors?
Big questions to ask, it's just not about the turbo.
