rate your mods - take 2
Old Apr 14, 2009 | 08:13 PM
i'll start again and hopefully this time it wont get locked or cluttered with flaming. the rules are simple, name a mod and give a rating. if you'd like to give an explanation for the rating it would be beneficial. for the rating you can use stars, letter, or numbers, just give a fair rating.
obx header 7/10 - would have been a 9 if i didn't have to beat the firewall in to get the 02 sensor back on.
fidanza flywheel 6.5/10 - the engine revs faster and tb response is great but i feel like i lost some torque.
drive shaftshop 1pc steel ds 7.5/10 - not much to say other than tb response is improved even more and there is not hesitation when accelerating compared to the stock ds.
colt cams stage I tri flow cam 8/10 - again not much to say other than there is a definite gain in hp.
msd 6a ignition & blaster ss coil 6/10 - yeah there's a difference in the idle and sligh increase in mpg but other than just looking good under the hood i can't say i'm too pleased.
custom intake with K&n filter 7/10 - the stock air box even with a drop in k&n seemed to be choking the poor ka upon full throttle.
these are some of mine so who's next?
Old Apr 14, 2009 | 08:42 PM
shaban's Avatar
SR20DE-T - 8/10 - good motor, can handle a good amount of power on the stock block.
Garrett GT2871R - 9/10 - Great if you're drifting because of quick spool, really lets you feel the power of the SR20.
Spec Stage 3 Clutch - ?/10 - mine wasn't properly installed and sucked, so I will not give it a poor review.
Venom 550cc Injectors - 2/10 - awful, had to order two sets of injectors, in both sets, 2 of the injectors didn't work.
Apex'i SAFC II - 6/10 - good for a safe tune, but not so good for precise tuning.
Megan turbo manifold - 7/10 - pretty good so far, but I hear that their welds crack a lot of the time. Good for top-end power.
HKS Catback exhaust - 8/10 - looks and sounds great, but I need to go bigger, 2.5" is choking my turbo.
Ebay Intercooler - 9/10 - hasn't given me a single problem
Ebay boost controller - 7/10 - have to readjust every once and a while
D2 Racing Coilovers - 7/10 - not bad for daily, improves handling, can handle sport-driving, but would suggest higher end coilovers for motorsports.
Sportmax 962 wheels - 9/10 - heavy, but cheap and look good.
B&M Short Throw Shifter - 8/10 - vibrates a lot, a little noisy, super short throw.
ACT Prolite 10.5 lb flywheel - 9/10 - pretty good so-far have had it in less than 1,000 miles, but increases response time.
240sx (doesn't count as a mod) - 1/10 - piece of ****.
jramosthe1st!
Aug 23, 2007 10:04 PM
Bryan
Sep 13, 2005 11:45 PM
ploofka
20
Jul 9, 2004 07:03 PM
irax
Mar 30, 2004 04:13 PM
ryan15
Mar 7, 2004 11:18 PM
