really tight ebrake
hey guys,
i did some drifting for a video project yesterday and when i got home and pulled my ebrake it was really tight. well it is still tight today...did i mess something up? what do i do to fix it? can i just loosen the ebrake? |
Take the cover off and look inside, there should be a nut, try loosening that...
you use the E-brake for drifting? com'on man you should be better than that
yeah i know you can just loosen the e brake, but if it suddenly tightned up like that you might have warped the rotor, e brakes aren't made to be used like that so if you use it often thats one of the problems that you will come across especially if its cold outside, kinda like putting ice in a hot drink and cracks.
thanks for the info guys. i need new rotors and pads anyways so owell. and no i dont use the ebrake for drifting...duh? :}
hmm I have had the exact opposite problem that you. last time my hand break becam hella loose suddenly. but I think rear break was lock and it burn all my pad and I had to replace the caliber and rotor too
