Removing Passenger Window & Window Regulator?
How exactly do you get the window and window regulator out? The work manual I have for my 240 isn't detailed enough and doesn't describe how to remove it. I was in a Pull a Part kinda place today and my dad and I tried every possible thing to get it out. We took off all the nuts from the bolts that held the window regulator to the door frame, took off all other nuts & bolts we could find that held the door together and we could still not get the window & regulator out. Is there some special way to removing it?
Hm thanks. I think we got all those bolts & nuts loose... I don't know why we couldn't get it out. I think it may have been those linkages to the door latches now that I've seen that diagram and thought about it; maybe they are connected to the window regulator somehow?
window regulator
How exactly do you get the window and window regulator parts out? The work manual I have for my 240 isn't detailed enough and doesn't describe how to remove it. I was in a Pull a Part kinda place today and my dad and I tried every possible thing to get it out. We took off all the nuts from the bolts that held the window regulator to the door frame, took off all other nuts & bolts we could find that held the door together and we could still not get the window & regulator out. Is there some special way to removing it?
180sxfan
09-08-2006 04:11 AM
Magius360
04-01-2006 08:22 AM
copycon
11-20-2005 12:51 PM
reefer1114
01-29-2005 10:51 AM
