Running lights
I have a 92 240sx with the factory runnning lights and turn signals. One of my lights keeps cutting in and out, I've replaced the bulb and its not the issue. One of my acquaintances who also has one similar to mine has the same problem. He said that apparently where the wiring splits to go to the other side is a regular problem on 240's. Any truth to this as I haven't heard it before?
Another question, my running lights have seen better days..anyone know where you can get replacement lenses? Thanks TJ |
moved to "General"
If it's not the bulb then chances are high that it has to do with the socket or the wiring behind it. YOu'd have to trace the wiring harness and inspect for any breaks, shorts, loose connectors, etc. first.
