-   General (https://www.s-chassis.com/forums/general-3/)
-   -   S13 Dual-Halogen replacement bulbs?? (https://www.s-chassis.com/forums/general-3/s13-dual-halogen-replacement-bulbs-9506/)
z0iid Feb 2, 2004 01:09 PM
I have the pre-projector s13 front end - also know as dual halogens, or just non-projector. The outside bulb replacement is a H4 ..... (i am pretty sure anyways....I replaced those a while back....im not so concerned about them)... but the inside bulbs are not anything standard that I have seen....
Anyone know what the exact bulb replacement is? The bulb does have a model like number on it....but when I went to the website for that company..... I couldn't find that model number as a replacement.....someone please help....I need to change these bulbs.
ixcocoyxi Feb 3, 2004 01:58 AM
if you have the old ones.. does it only have one wire comin out of em? and looks kinda like an h4? if it has just one wire to it.. most likely its an H3.. but im not an s13 pro.. :dunno:
SINxSELEKTAH Feb 3, 2004 08:06 AM
Re: S13 Dual-Halogen replacement bulbs??
Halogens (zenki):
Foglamps - H3c
Hi/Lo - H4
Dual Projectors (chuki):
Lowbeams - H3c
Highbeams - H3
Foglamps - H3c
Triple Projectors (kouki):
Lowbeams - H1
Highbeams - H3
Foglamps - H3c
There it is.
for the turnsignal/marker lights (side lights, not bumper), it's just 194 wedge bulbs.
nope...they're not H4s...i just recently replaced bulbs to my fiance's car....
http://members.ixp.net/selektah/s13.jpg
hope this helps...
-jaysin
z0iid Feb 3, 2004 10:39 AM
Thanks,
I will check if the H3C works.....but in correction to the bulb set up for the halogens..... it isn't foglamp, hi/low...
on lowbeam, the lights are as follows. = is highbeam - is low beam
[===][----]---silvia---[----][===]
on highbeam, the lights are as follows
[----][===]---silvia---[===][----]
thats how it is supposed to be wired. So the inside bulbs aren't foglamps - they are dual filament as well....and the high setting is angled high like a high beam is supposed to be.
