s13 projector/halogen lights
Old Oct 4, 2005 | 12:30 PM
wL-'s Avatar
wL-
hi, i was wondering if the projector lights will bolt right on a 89' coupe, i was also wondering if the projector headlights and the halogen lights are interchangable
(same size).
thanks
Old Oct 4, 2005 | 02:16 PM
Re: s13 projector/halogen lights
(same size).
thanks
Newb Freebie: Are you talking about the JDM Silvia projector headlights, or the projectors that fit into the space where normal US 240sx flipup lights are?
Old Oct 4, 2005 | 04:52 PM
wL-'s Avatar
wL-
i was talking about the jdm ones - sorry if i wasnt being clear. I was wanting to know if it easy to just switch the hood/fenders/bumper/headlights. I heard that the wiring is a little tricky.
projector:
http://img333.imageshack.us/img333/7403/temp10cq.jpg
vs.
halogen:
http://www.passwordjdm.com/product.a...umLanguageID=1
Old Oct 4, 2005 | 05:28 PM
don't forget light brackets. And wiring is easy if you know how to cut/crimp.
...and this info is in the forum in multiple places.
Old Oct 4, 2005 | 05:54 PM
nsn240's Avatar
not that bad, but it isnt just a simple task... like anything else, it takes time $$ and some experience. there's all sorts of information, please search!
Old Oct 4, 2005 | 06:33 PM
whatcha mean it's not just a simple task? Provided he gets all used OEM parts, and his lower fender area isn't all smashed to bits, it's literally bolt-on; then all that's left is some minor rewiring for the headlights to work
Old Oct 4, 2005 | 08:37 PM
naptime's Avatar
Originally posted by l2aine
..... it's literally bolt-on; then all that's left is some minor rewiring for the headlights to work
Yep. Take the OEM parts off and bolt your Silvia conversion on. You need the fenders, hood, bumper, (mine came with bumper support, but don't know if you need it) headlight brackets, and the headlights. If it doesn't come with the silvia center garnish, then get yourself a gtr grill or something. Save the nuts and bolts that you took off and reuse them. Mine came prewired so I don't know how hard the wiring would be.
Yes, the projectors and the halogens are interchangeable.
Old Oct 5, 2005 | 07:20 AM
wL-'s Avatar
wL-
by the way ill be using that clip i posted for the conversion that i posted for the projector headlights
do you think that specific clip will suffice partswise for a easily swapped front?
thanks
Old Oct 5, 2005 | 07:58 AM
nsn240's Avatar
I was talking about the paint and prep part, and getting everthing to line up nice
Old Oct 5, 2005 | 10:12 AM
thanks
well if the whole front clip is right there with the body/light parts, what else do you think you need? Like it was said earlier, it's completely bolt-on. hood, fenders, bumper, lights, brackets, support, grille. If you can see all those parts on the front clip then guess what?
phreze
Oct 29, 2005 09:36 PM
n0odlez
Apr 29, 2005 08:55 AM
z0iid
Feb 3, 2004 10:39 AM
Haisai
Oct 15, 2003 08:57 PM
Haisai
May 6, 2003 08:30 PM
