S14 Steering wheel wiring help
Hey guys i need some help with wiring up my MOMO Mod 21 steering wheel, and my hub is HKB Boss Kit, my issue is wiring up the turn signal. Ive searched through this forum, and also have importnut as a favorite.
When i tugged the steering wheel off the white harness part got ripped (in the pic below)
i spliced 3 of the 5 wires however, but not the 2 wires that went to the air bag module since i wont need it right.
basically im stuck, i do not know how to re-wire up the turn signal, also at this point my ignition will not turn, only thing the works is head lights, high beam, dome interior light. Please help me out, i know this is a easy mod, i dont usually ask for help, but in this case, i do. Thanks.
cut or take all the wiring and black rotating piece thats screwed with 4 screws aroung the shaft there off. You don't need any of those wiring, only wire you will need is the horn wire when you hook it up in the way that you want to. The signal should not have anything to do with those wires you got in the pics. the three little nipples around that blue ring on the shaft there is what clicks the signal off after the turn. If you hub does not have 3 holes behind there then you will need to drill 3 holes only big enough and deep enough to go over the 3 on the blue ring. Make sure to align it before drilling and make sure it's a perfect size drill bit so it turns the signal off when your steering will rotates back to nomal position it clicks and turn you signals off. I have a grant so thats what I had to do, also made my own horn buttons.
Bryan
Jan 24, 2006 11:54 AM
