s15 steering wheel problem
I have a problem with my s15 steering wheel, after installing it in my car, everything worked out fine, my horn works, and my airbag lights come off like regular steering wheel.
the 2 problems i have with it is that is makes this clicking noise when i turn it, its annoying to a serious level.... another thing is usually when you turn corners, your steering wheel shift it self straight, but in my case, its really slow at doing so. anyone else experience this?
the only thing i can think to tell you is check and make sure you have clearance between the backside of the steering wheel and your column covers. if they are touching each other it could cause both your problems. If they are then you could make a spacer to correct the problem.
Bryan
Jan 24, 2006 11:54 AM
mextaliano
Dec 29, 2004 10:44 AM
