View Poll Results: Would you use the APEXI, or SMT6 or both??????
How many like APEXI raise your hand
100.00%
How many like SMT6 raise your hand
0%
Would you use both
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
SMT6 VS. APEXI Controller
Alright guys here is a short story I purchased my apexi controller a few months ago great unit to have to shift the power band, and actually increase more Crank Horse Power by dumping more fuel. Also has a detailed display and mounts to the dash or roof of any vehicle. Is great to look at for display input and outputs. I only payed $265 for my apexi. But the down side to the apexi is that it doesnt change the frequency responce to the temp output signal....... But the APEXI is much more verstile and easier to use.....
http://www.alamomotorsports.com/apexi/safc.html
Lately I've been researching other piggy back units such as the SMT6 which can also be used on any make or model OBD vehicle. With the smt6 you need a laptop and a program to reprogram. But it allows you to change the ignition map, that means with advance tuning on the cams or distributor you can change the timing ignition on the BTDC...........
I've left the link so you can do the research yourself......
http://perfectpower.canspeed.com/smt6.htm
What do you guys think APEXI SAFC or the SMT6??????????
Or would it be possible to link both piggy backs???????
C'mon guys no responce from the peanut gallery??????
Isn't anyone into enginemanagement??????????
I guess noobs arent that smart, I'm lookin for some 2 cent's here......
haha iv heard alot about the SAFC II i dont know alot about engine man. yet
i had a question dose APEX'i make a power FC for are cars? iv heard there the best...
You can use the Power FC if it is programmed for a distributor 4 banger nissan engine. If you convert the KA to distributorless, a "DIS" then you can use the Power FC that is compatible for the CA18DET, and SR20DET, all the engines run on the same sensors.
SAFC Super Air to Fuel Converter is much more simple and is for a street tuner.....
The power FC isn't streetable, or atleast in the state of Cali......
Yeah I guess I'm lucky I have a 91 KAde for that AEM then.....
I would do a stand alone also but it isn't cost effective, when retailers get smart and sell them for what they are worth which is around $800 I'll be there to pick one up.
I think the SMT6 retails for about $400 and has much more programming than the SAFC which I will remind you I picked up my SAFC for $265.
What I like about the SMT6 is that it can change the input signal to the timing ignition "ignition MAP".....
You can play with the power band more with the SMT6, allowing to optimize power and efficiency....
As for me the SAFC is fine for my application, I am investing into adjustable timing gears, and wiseco 11.1 CR forged kit through Nizzx. I will manually shift the power band through the distributor and timing gears...........
Around $400? Damn, in that case I'd definately get the e-manage, You can buy them off ebay around $250. Ofcourse it's more once you add on the accessories but it looks like it'd end up cheaper than the smt6 and it has higher resolution maps as well.
underground
Jun 16, 2007 08:45 AM
jic-life
Mar 15, 2005 01:20 PM
ravspec
Jun 18, 2004 10:05 AM
ahnyoungboi
May 18, 2004 02:27 AM
