Steering Problems
Steering Problems
On the freeway my 96 240 wonders easily and seems unstable. Could this be a worn tie rod? It also makes a wierd noise when the car is warmed up and the wheel is turned at a stand still. Help me please.
Thanks
Thanks
I have been under car looking for any leaks and can't find any, my levels also seem to be fine. Maybe the power sterring motor? But that woulnd't cause instability. I don't know, anyone know?
the car also wants to pull right when braking...once I realease the brake its an instant readjustment and the car goes straight again. Something has to be loose, but I can't figure it out.
It sounds like the tension rod bushing on one side is wasted , The black rods that run from your lower control arm(bolt to it with 2 bolts) and run up to the front of the car on a angle , Check the bushings on the front of the rods , Also make sure the bolts are still tight where it attaches to the lower control arm ....
Re: Steering Problems
Thanks
Thanks
Bryan
Jan 24, 2006 11:54 AM
