stereo/clock/electric problem
Old Jan 13, 2007 | 02:05 AM
EJ253's Avatar
hey guys, i got a problem today in my S14. when i turn off my car and then turn it back on again (after any amount of time) the clock resets to 1:00 and the stereo turns off and goes to demo mode. earlier, i was driving and the stereo just turned itself off. i pressed the button and turned it back on, thought it was kinda weird.
as for electronics i have a Viper alarm and a JL audio sub that has been unplugged for 2 or 3 days.
any ideas of what could be wrong? the other electronics (dome light, headlights) still work fine when the key is out. this is kinda annoying and i dont want this is cause anything else to happen.
and my sub isnt working either right now (it might have nothing to do with this problem tho).
should i take it to the dealership? keep in mind i have an SR/heavily modified 240
any suggestions are appreciated
thanks,
Greg
Old Jan 13, 2007 | 09:08 AM
EJ253's Avatar
anyone have any ideas?
Old Jan 13, 2007 | 10:24 AM
Zenki_SliderS14's Avatar
Did you check your fuses?
Old Jan 13, 2007 | 10:46 AM
EJ253's Avatar
someone said it might be a fuse. i dont have the kick panel next to the clutch that covers those fuses, if someone could take a pic of the fuse box cover so i know which fuse to look for, thatd be awesome. i dont know which is which. thanks
*i hope its just a fuse.
Old Jan 13, 2007 | 04:33 PM
well if it comes on and off by itself its not the fuse. mabey a short somwhere.
Old Jan 13, 2007 | 10:27 PM
conweezy's Avatar
heh
or you could go to a junk yard and check it out there thats always helps and you sub not working did u try and plug it in mayb thats not y its working but all else fails hit up the dealer they will hook it up fer sure but charge u up the *** for it but at least itll work
Old Jan 13, 2007 | 10:37 PM
My head unit did that when my alternator started to go out. It couldnt hurt to test that.
Old Jan 14, 2007 | 01:18 PM
EJ253's Avatar
it only did that once. then i started to have the problem.
Old Jan 14, 2007 | 01:19 PM
EJ253's Avatar
ill probably stop by the dealership on monday or tuesday to see if they can order the kick panel/fusebox cover and see if they can take a look at my problem. are the dealerships usually cool with SR20 swaps?
Old Jan 14, 2007 | 01:24 PM
EJ253's Avatar
im about to just check the volts myself. where would i go to have it professionally checked?
Old Jan 14, 2007 | 02:48 PM
Autozone will check it for free, or you can do it with a multitester.
Old Jan 14, 2007 | 02:52 PM
EJ253's Avatar
cool, thanks for the info
Old Jan 14, 2007 | 04:15 PM
EJ253's Avatar
volts seem fine. ill check my alt tonight
FlyingS13
Oct 24, 2005 07:51 AM
Preston
Jan 15, 2005 02:23 PM
Amolao
Jun 5, 2003 04:49 PM
drifties151
Nov 29, 2002 11:14 AM
