suspension techniques sway bars questions
hi, i just got my set of susp. tech. sway bars. i have two questions here. first one is when i was installing the rear sway bar, the Hex Head Cap Screw they privided was a bit too long, the nut could not tighten all the way to hold the bushings.
second is they privided 8 flat washers, but on the instruction, it ways " you must place two flat washers, on top of each other, between the bushing bracket and the mounting surface on the rear hole of the bracket". this means, there will only be 4 washers used total, so, 4 are left out. is that right?
thanx
thanx
Scuderia
May 21, 2007 12:31 PM
Champster
Aug 2, 2006 08:16 AM
Black Komet
Feb 27, 2003 10:27 PM
S14Drift
Nov 29, 2002 05:54 PM
