-   General (https://www.s-chassis.com/forums/general-3/)
-   -   Are these fuel injector good? I need to fix my car fast (https://www.s-chassis.com/forums/general-3/these-fuel-injector-good-i-need-fix-my-car-fast-36386/)
jackyliem Dec 14, 2006 01:31 AM
http://www.autopartswarehouse.com/bi...206-4/cvu.html
I wonder if anybody has experience on this. The price is pretty good for 4. My fuel injectors have been leaking for a while and I need to fix it fast. Other than that, where can I get cheap and decent fuel injectors? thanks !!!
Bryan Dec 14, 2006 06:14 AM
Should be fine, they have a warranty too. You could always find someone local with some stockers laying around...also be sure that it is the injectors themselves leaking, it may just be the o-rings and insulators, which you can replace without doing the entire injector.
jackyliem Dec 14, 2006 10:07 AM
I can only find about a hundred dollar per piece around. so I guess I will go for it. Well my ECU does pull code for fuel injector leak. but could it be caused by other problem? and I just check my o ring. they are fine
Thank's again.
jramosthe1st! Dec 29, 2006 11:22 PM
if you still need an injector i have some extras from a spare engine.
