ticking noise
yes i'm have unlimited problems with my s13 single cam.....so theres a ticking noise....and some times it's real bad and at others it ain't so bad..you can here it when i accelerate ...i'm not too sure what it is....but it's coming from the engine area
Knock???
timing belt guides.
my first impulse is to say that it sounds like low oil pressure which leads to lifters ticking. the sohc can be rather noisy though so it may or may not be it.
Sounds like a bent valve
well at times i check and there is low oil i refuel it and it kind of goes away but when i checked the oil to day it seems to be alright
I agree with jramosthe1st, thats usually what a ticking will be my second guess would be timing belt guides.(I'd hope it was the timing belt guides) Its the easier fix
timing chain not belt
Originally Posted by Pillion240sx
(Post 385323)
Correct me if I am wrong. RickY |
Originally Posted by FuriousZ
(Post 385335)
I don't think KA24E have issues with the timing chain guides.
Correct me if I am wrong. RickY when i suggested low oil pressure i wasn't referring to the oil level. there may be a relation between the two in this case but that is not always so. low oil pressure can be a result of a number of things that range from a simple and fairly inexpensive repair to a complete engine rebuild. vinnie mentioned a bent valve and that too is a possibility. so to rule out one or the other i'd do a compression or leak down test and check the oil pressure as specified in the fsm. |
ok once i get that compression test i'll let you guys know what it says
Nope your right ricky my mistake good eye
| All times are GMT -7. The time now is 04:45 AM. |
