trunk rattle...
sry for the spam.... but my trunk is rattling alot and i dont even have a sub does any one know how to fix this problem if so plz tell me or email me the step on how to do it thnx a lot
another thing my trunk doesnt shut tight...like if i press down on it i can feel the trunck move down |
Re: trunk rattle...
Originally posted by supr_mino sry for the spam.... but my trunk is rattling alot and i dont even have a sub does any one know how to fix this problem if so plz tell me or email me the step on how to do it thnx a lot another thing my trunk doesnt shut tight...like if i press down on it i can feel the trunck move down And post in the right section next time... this has nothing to do with audio. |
Moved to general
to remove trunk rattle you do as follows.
1. loosen the bolts holding the trunk latch to the body of the car. 2. move the lack down about 1mm or so. 3. tighten bolts back up this will cause the trunk to close and pull tighter to the body if this dose not help you need to do some real work to get the seal right. |
this sounds kinda dumb but this is what i did. i went to the local bicycle shop and bought a set of real cheap handle bar grips that were soft rubber like material. i cut them about an inch up from the closed end and pushed them on to the rubber stoppers for the trunk...hasnt rattled sense then. worked like a champ and you cant even tell that they are there cause the are bleck rubber just like the factory ones. ill post a pick here soon.
Originally posted by 2fast4y0u this sounds kinda dumb but this is what i did. i went to the local bicycle shop and bought a set of real cheap handle bar grips that were soft rubber like material. i cut them about an inch up from the closed end and pushed them on to the rubber stoppers for the trunk...hasnt rattled sense then. worked like a champ and you cant even tell that they are there cause the are bleck rubber just like the factory ones. ill post a pick here soon. |
My trunk rattles with a gap also but my trunk release doesn't work. Has anyone had this prob and what do you suggess? I'm guessing the cable snapped but I don't know how to get to it.
its either that or you need to adjust the locking mechinism. just undo the bolts a little and move it. then retighten
and yes thats pretty much what i did. you cant ever tell that they are there. its pretty nice |
Aight. I'll try it tomorrow. Thanx
no prob and good luck
Got my trunk release to work And figured out that I'm missing the rubber stopper on the left side of my trunk. I'm going to the nissan dealer to get and hopefully the rattle will stop
| All times are GMT -7. The time now is 02:48 AM. |
