Uneven headlights
On my 91 240sx my headlights are uneven when I do the sleepy eye. If there all the way down or up there even, but once I do the sleepy eye by tapping my headlight hold switch the driver side one is a bit higher when I do it. So is one of my motors shot? or is it out for adjustment? I'm lost. Thank you
One of the motors is probably just slower than the other. I don't have an s13 but I think you can adjust the little gears to offset it a bit.
yes sir you can to the left and right of each headlight.. there is a motor. you pop the top off and adjust the height. also remove the bezel around the light.
you adjust the beam with the two screws |
Alright well I knew that I can adjust them up or down with the red knob on each side. but once the lights cycle up and down they go right back to normal. I think my driver side motor is slower cause I watched them today and my passenger side stopped a split second before the other
get new motors..... nothing you can do about that.
/thread?
