What to do what to do?
not what would we get.
but whats best for you to spend that kinda money on.?
what do you need/or want? what are your goals for your car? what do you want it to do?
its all about planning in order of making the car truely road worthy and then fun worthy otherwise your really taking chances breaking things worse when you dont expect it if you dont know what needs to be fixed before you start playing too hard. bushings? leaks? tesion rods? tie-rods? tie-rod ends? lsd?
what kinda and what have you done with your suspension and exhaust?
what motor do you have and or plan to use?
all of this info will help us help you better
Well I already have a s14(95) with the sr20det swap, Hipermax suspension, and HKS dp and exhaust. Just found out my rack and pinion is going bad(leak) which i'll probably fix before it gets on the road, I think im going to get the 5 lug rear, since i already have the 5lug front, and the TE-37s wont fit without the rears
other than that, what would be next? Im leaning towards the look of having a Front mount plus the proformance that comes with it. I plan to do track and some autoX, up here in AK we dont have much track time, we only do it in the High school parking lots (hella gay, with the cones and whatnot) but we have the 1/4mile track so more toward thes drag.
