Why is there a hose routing the crank case to the intake?
As mentioned in topic.
Can I just put a breather on that crankcase hole and plug that hole on the intake pipe? or is there any reason to keep the crankcase vaccume? Thanks !!! |
it sucks pressure from the crank case/valve cover... yes it has a reason. you should buy a catch can if you want to do it right
btw, you have 240 posts haha |
As the engine runs, pressure builds up in the crank that has to be vented out. PCV has something to do w/ crank vintalation too I think.
