New product! ECU Patch Harnesses
Hey guys
I just wanted to take this time to let you know about a new product we now offer, the ECU Patch Harness. For those of you who are not sure what this is, i'll explain. The ECU Patch Harness allows you to bridge between your oem (or Wiring Specialties) wiring harness and ECU. With this harness in place you can install accessories such as turbo timers, electric meters, SAFC's, and anything else that requires tapping into your wiring harness for s signal. The ECU patch harness eliminates the need to cut into your factory harness and allows you to wire up accessories outside of the car with ease. No more crouching in the foot well of your car, on your back, trying to connect wiring in a tight, dim lit environment. Each and every Patch Harness uses OEM connectors/plugs and installs in seconds! You can quickly and easily take the patch harness out of the car to your accessories and then plug it back in.* People looking to sell their vehicles in stock form can enjoy selling a vehicle without having a hacked up wiring harness from where your electronics use to tap into.* Harnesses are available for all or most SR, RB, VG ,CA and KA engines. The engine can be swapped or OEM which means you can run this in your SR20 powered Datsun 510 for example. You can learn about the product and compatibility on our website: http://wiringspecialties.com/ecupaha.html |
S14 KA24, VR38DETT (GTR) and VQ37VHR (370Z/G37) patch harnesses added!!
| All times are GMT -7. The time now is 04:46 AM. |
