-   How To Requests / Questions / Tips (https://www.s-chassis.com/forums/how-requests-questions-tips-49/)
-   -   5 speed swap write up please (https://www.s-chassis.com/forums/how-requests-questions-tips-49/5-speed-swap-write-up-please-47137/)
justgotta240 Jan 21, 2011 04:23 AM
i have slowly but surely aquired all the parts for my 5 speed swap. i even had a chance to take the tranny to my skool and have it taken apart cleaned out its actually in GREAT condition for free lol
(also if any1 needs a tranny cause there tranny is messed up i have another 1 its just one tooth is chiped on 5th gear and reverse not haveing a syncro leads to a lil bit of grinding or something like that so the edge of reverse is a little messed up bit im sure itll work for a temp pm for info)
i bought a clutch exedy oem fit or what not from bap geon for 110
and im looking for a write up on the swap that the pictures are actually good or working for that matter
please and thank you
also just as a side note i have passed my 4th mod in school i got a 96 A in drivelines 1 (manual transmissions) go me :beerchug:
so thats electric 1, basic engines, steering and alignment, and drivelines down next up is brakes i start monday
battosaii930 Jan 21, 2011 03:10 PM
just did the swap on my buddies s14
its pretty straight forward if you have the right tools, ive been a mechanic for almost 7 years so i had all the tools i needed just wish i had a lift at home lol
justgotta240 Jan 28, 2011 11:47 AM
well its mainly the wiring that gets me ya know i dont know how to wire up the reverse lights i could sit there for 2 weeks trying to plug and play and what not but im trying to get this done pretty soon so like where do the automatic reverse lights hook up at?
and 2 questions
1. where can i get bolts for the flywheel and tranny
2.how much fluid does this 5 speed transmission take? and what kind should i get
jramosthe1st! Jan 28, 2011 03:14 PM
all that can be found in a fsm.
justgotta240 Feb 2, 2011 11:21 PM
and how many bolts hold on your pressure plate? 3 or 6?
my friend told me 3 the dealer told me 6 im seeing 7 holes on my flywheel and they are all threaded except for like 1
and btw does it sound right that there are 2.5 liters in the manaul tranny cause i cant get this fill bolt out to save my life and i have to fill the shifter
i have ben really busy in skool and havent checked alldata for random stuff like that
justgotta240 Feb 5, 2011 10:22 AM
ok scratch that i figured everything out so im good as far as all that
im looking at a flexable clutch line any1 have any experiance with these things? they cut out the dampener and rather then running a second line from the hardline to the slave just run the softline
battosaii930 Feb 5, 2011 11:15 AM
flywheel has 6 bolts
i got the transmission bolts from Home Depot
Bolts = 08131-0601A / 60mm length / 4 needed
Washers = 08915-2401A / 4 needed
Bolt = 08131-0701A / 70mm length / 1 needed
Washer = 08915-2401A
Bolts = 08124-0301F / 35mm / 2 needed
Nuts = 08911-2401A / 2 needed
Bolt = 08124-0601F / 65mm / 1 needed
Nut = 09811-2401A / 1 needed
Bolt = 08071-0251A / 25mm / 1 needed
Starter Bolts = 01121-03751 / 95mm / 2 needed
all bolts are M10X1.5
i didnt bother with the reverse lights lol
other then that there is only 1 wire in the fuse box to jump and the car runs at 100%
